Alright, so my clutch won't let me get into gear. I tried to bleed it and that didn't help. its either the throw out bearing or something in the piece that the bleeder valve is in. how hard is this part to find? is it something that a local parts store will have or have to be ordered from mazda?
Clutch Problem
The clutch slave should be pretty easy to find at the parts store. So, when you bled it, fluid came out? When you press on the pedal, the slave doesn't move?
when something like this happened to my old 91gt The clutch pedal pushes this rod that has a ball on the end into the shift fork or something that pushes the throwout bearing. well the little ball had went threw the thing it pushes. so the tranny had to come out to fix. just something else to look into.Cincinnati, ohio Bengals for life
"Who Dey"
