Ok so the 323 (with a bpt) has been having some sketchy acting up going on. I have replaced the radiator atleast 3 times now thinking if was faulty radiators, it would also randomly start to overheat and most the time the needle drops back down to the middle, if not, i turn the car off and restart with the needle back to the middle...it's not that cold in bama to cool an engine in 5sec. now i think it's other problems.
Some of the things going on : The idle is too high, on the boost gauge (when at idle) reading vacuum fine for a bit, then the needle starts to jump between about 14-20vac. like a spaz. but when i tap the clutch pedal it stops and goes back to steady 20vac. Also have oil leaks coming from the valve cover (changed several times as well) I have been thinking that I'm boosting the wrong parts of my engine due to bad head gasket (used old head bolts when rebuilding the motor). ANY questions/ideas please post up!! It's getting very tiresome!!
Thanks a lot!
another thing forgot to add, while driving when i go to shift and engage the clutch, my rpms increase extra 100-300rpm...usually when "revving" they decrease very slowly to the high idle, 2000-2500 mark
Thanks a lot!
