iI called the techs at mazda to find out about this seatbelt recall i hear so much about only to find out that my car is not covered but as a 91 model year cause it does not have the same issue of the 92+ year cause the vim is not included in the recall oh well i guess im going to have to get a set from the junk yard cause they wanted 1400$ to fix both of my belts.
bg seatbelt recall fail
Canadian manual belt swap?1990 Protege 4WD
1 3 5
2 4 R
usually what you have to do is go above the dealer... of course a dealer doesnt want to take a crappy free job away when they could charge you 1400 dollars. its when mazda corperate gets the call that people start doing things. Not that its set in stone going to get this resolved for you, but its worth a shot.There are no stupid questions, just stupid people.
Originally posted by FazdaBoy4ever View Postusually what you have to do is go above the dealer... of course a dealer doesnt want to take a crappy free job away when they could charge you 1400 dollars. its when mazda corperate gets the call that people start doing things. Not that its set in stone going to get this resolved for you, but its worth a shot.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
