Will grade 8.8 bolts work for pressure plate (DOHC)?
I wouldn’t recommend it, they are under a lot of tension. Try www.mcmaster.com or see if someone here can send you the stock bolts from a spare flywheel etc.
I don't know what size you need but Bolt Depot has grade 10.9 bolts in the following metric sizes:
6 x 1.0
8 x 1.25
10 x 1.5
12 x 1.75
14 x 2.0
16 x 2.0
they are 8x1.00 and 18mm long. I thought they were only 8.8 grade though? Thats what I bought a couple months ago and am using. But if the factory used grade 10.9 I would get them if you could. Don't forget the lock washers.
they are 8x1.25 and 18mm long. I thought they were only 8.8 grade though? Thats what I bought a couple months ago and am using. But if the factory used grade 10.9 I would get them if you could. Don't forget the lock washers.
Unless what I told you ended up being wrong, they are fine-thread M8x1.00.
metric grades go 8.8, 10.9, and 12.2. similar to SAE grade 2, 5, 8. if you can find them in 10.9 I would go that route, its best to match whats in there already.
there is a company call fastnall (maybe misspell) that carrys every type of bolts. if you cant find them in your area, let me know i can take a trip and help you out. thats where i get my stuff when other places fail.
