so im a escort guy with a 1.8 swap ps and ac delete. andi was wondering if theres any 323, proteges, or somthing with out power steering that has a better steering ratio? also my escort whn it had the 1.9l didnt have power steering and i didnt wana swap it over. so thats why it doesnt have it.
ok quick question
try 323 manual rack i heard it somewhere here lemme find it
EDIT:here it is
is that what u are looking for?Last edited by bp_turbo'd; 12-21-2010, 10:22 PM.swapping into another shell!
so when i "depower' it it wont be heavy? because my friend had ps in his civic and when he re did his motor and did a ps delete it was heavy to turn mine didnt have ps to begin with so i dont wanna get a rack that was ps and have it be heave to turn still
and thanks for the advice tooshe may not be pretty, she may not be fast. she may not always get me from a-b but damnit shes all mine.
he was looking for a quicker ratio rack as well. i believe the manual rack has a slower ratio than the power racks91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
it was heavy because the rack probably still had fluid in it. it needs to be totally drained91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
its the mx3 rack and you will have to get the steering shaft as well. i tried to swap the racks out in my escort and they had a different coupler to the steering shaft1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 EGT - Junked May 2012
