    bo, this is un acceptable. im very disappointed. lol
    haha jk nice numbers
    93 Mercury Tracer SW
    01 Honda S2000 Future Boost
      I don't have many other figures to base these off of since most people here are wrong wheel drive :p
      NW MAZDAS
        I don't have figures to post, but those numbers are way better than mine. Now you just need to address that curve.
        1990 Protege 4WD
        1 3 5
        2 4 R
          Yeah I need to mess with the boost levels and such
          NW MAZDAS
            I spent all damn day changing out the oilcooler hose that wraps around under the intake to the passenger side.of the block. How very not fun. While I was at it I changed the accessorydrive belts.
              Im pretty sure my car is capable of hitting 130mph.... that was dangerous.
                heh!......... want my gearing you could probably compete in nascar races.......
                Installed my Front strut tower bar again, re-torqued my cam journal caps, and re-filled my tires with air. passenger side front was 4 psi lower then the drivers. and i was noticing a slight pull
                  Let her know I still loved her by taking her to the dollar vacuum at the car wash. lol A little less neglect goes a long way.
                  Team Fail Motorsports
                  That's just the nature of the beach.
                    Trying to decide if I should drive mine for a while with a cracked manifold... if I put some of that epoxy on it, will it be ruined for welding in the future? Stainless BTW.
                    1992 Familia GT-X
                    1988 323 GTX
                    2011 F150 Lariat Ecoboost
                    2014 Civic Touring
                      epoxy wont do **** on an exhaust manifold. I would just take it off and get it welded up if you cant find anyone to do that then buy the expensive wire so you can use your mig welder.
                      bp swapped escort lx, gtr ecu, gtr intake manifold, A code VAF, rx7 460cc injectors, ky clutch, holset hy35 turbo on 8lbs, 38mm tial wastegate, ramhorn manifold, full 3 inch ss exhaust, walbro 255 fuel pump
                        took off the old purple tint and cleaned it up a bit. Adjusted the front seat belts onto the lower bolt hole. My neck thanks me
                        1993 Protege GT
                        1993 miata lsx swap
                          my shifter bushings either came off or got loose! I got the sloppy shifter feelin going on now. ugh.
                            ya rub it in haha, my US chassis only has the one set of bolt holes :/
                            ruh-oh! time to lift her up and check, don't want the shifter falling out lol (speaking from experience)
                              Work was cancelled today due to "Frankenstorm", so I took the time to get my PSC/Skuce manifold off and down to the welding shop. Once off, I found it was way worse than I thought; almost every weld broken. I wish I had of taken a pic.
                              I will post pics of the repaired manifold when I pick it up next week.
                              1992 Familia GT-X
                              1988 323 GTX
                              2014 Civic Touring
                                ya i went under and to find out the weld that was put on the shifter linkage had broken off. i grinded it off and put in a bolt with a nut and also a locking washer to hold it in. now that should do it for a loooong time. i will have one of my buddies put a weld on it for xtra strenght lol.
