Originally posted by atomicEGT View Postdoes the RB20 have the same over-oiling and heat retention issues as the 25/6?
Found the car:
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Random fitment photos.
I'm going to have to make a really weird actuator bracket so it doesn't block the blocks water/oil ports. It doesn't contact the water return under the exhaust manifold though, which was a concern.
Here is my factory fresh looking ac mount bracket. It still isn't cut down enough here. It needs a bit more cut off the top most portion. I was tired of dealing with it and just rattle canned it black until I do an IC fitment mockup.
And a closer photo of the clutch line/motor mount clearance.
It's going to be a bit of a rats nest in this area.Beater=/= Sleeper
I'll just put marine grease in the bearing oil passage and seal it up while I'm at it.Beater=/= Sleeper
coolant connections really only make a difference if you shut it down hot... as long as you "turbo time" it when you come to a stop, oil only is fine...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
With the minimal amount of oil traveling through a BB turbo I wouldn't feel comfortable running it oil only.Beater=/= Sleeper
BB is less sensitive to oil issues than a journal bearing anyway so if you cant run the coolant due to space issues it wont be a deal breaker.92 Mazda MX3 GS> For sale, $1750 OBO
Yeah,466541 Center section. I wish I could of picked up the one with the inconel wheel, but the premium for that was too much for the minimal benefit.
It's 2015 if you're not going BB you're poor, but that's just my opinion.Beater=/= Sleeper
Originally posted by 300zxrb26dett View PostBB is less sensitive to oil issues than a journal bearing anyway so if you cant run the coolant due to space issues it wont be a deal breaker.
With a .04 restrictor I don't think enough oil would pass through it for optimal cooling, I know water cooling is mostly for oil coking prevention but with how big the water passage is on this turbo I'm sure it's beyond an optional function.Beater=/= Sleeper
Originally posted by Kitty View PostYeah,466541 Center section. I wish I could of picked up the one with the inconel wheel, but the premium for that was too much for the minimal benefit.
It's 2015 if you're not going BB you're poor, but that's just my opinion.sigpic
92 240SX: KA/T25, nerd mobile
