Hi,
Trying to hook up a MSD SS ignition coil, I was looking at the diagram; I see a Y/BL wire coming from the igniter and a BL wire going to the ignition switch. I'm assuming they both hook up to the positive on the coil but were do I connect the negative. Do ground it or do I connect it to the negative battery terminal? If this was a non electronic ignition, I would route it to the condenser that would be located on the distributor. Need some help here if possible.
PS: I tried to do a search and ran into a road block finding some subject matter that was related but not what I was looking for.
