the seats in the pro recline pretty far back, right.
A little bit on the progress of the 323 ....
According to my Anger Management Counselor, after 26 weeks of anger management class, I should be an expert when it comes to Anger Management...tell that to the guy who threw a starburst at my car in rush hour traffic...haha
Todays thought of the day:
Mitch Hedberg
Originally posted by 1ofdfew323so with the miata pistons...will that be any better than the stock bp pistons? I mean will it be stronger. is there any gains in hp/torque? will it increase the compression ratio?-------------------------
'91 LX
'03 Mazdaspeed Protege #235
Originally posted by red90protegelxhmm bruce, if i bought the pistons, rings, headgasket etc, would you help me install it if i drove up there?
But once I do my motor I will know for sure what will have to be done when rebuilding. I also have a good amount on my plate with my 323, my protege and also helping john put his car together. Not to mention summer school is coming up.
Originally posted by 1ofdfew323yeah but is the miata piston any stronger than the bp? cuz wut bruce told me he will be shooting 100 shot of nos on this bp and bumping up the comp ratio aint gonna help.
later
Bruce
do you have to do anything to fir thos mitia pistions in or is it a straight swap?91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
Originally posted by TweeaksSo what would it even be worth buying Forged Wiseco Pistons w/ rings for $500 or better off staying with BP Pistons?
me! I am using stock internals on both my BP's... the pistons in the 96 protege engine in my 95 protege are stock. The pistons that are going into the 91 BP block from Adam's car are stock BP pistons...
I intend to run eventually 10 to 12 psi in the protege,,, if I blow a pistons I will just order another one ... 45 bucks shoot it can't hurt right.
Also to fit them in you just need to rehone the block and then install them . At least as far as I know..
I am not pro, just a guy who is to cheap to frigin pay anyone for anything..
Originally posted by bruce95fmlaAlso to fit them in you just need to rehone the block and then install them . At least as far as I know..
Originally posted by bruce95fmlaI am not pro, just a guy who is to cheap to frigin pay anyone for anything..91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
honing the sidewall... after awhile especially on a higher mileage car the cylinder wall tends to polish itself out from the piston ring rubbing on it on a cold start. U have to kinda scratch up the cylinder bore w/ a hone-type brush"ball hone". U have to do this becuz they can cause poor oil control and excessive blow-by.
rebuilding motor is alot of job make sure measure the oil supply on the main and rod bearing journals. must be smooth surface at the bearing area. The bearing must fit tighly enough to eliminate noise but must also have enough clearance between them and their bearings to allow an oil film.
