1991 DX. So 2 days ago I was driving home and the check engine light went on for a second and the engine stumbled. I thought "Huh". Went off for about 10 seconds then came back on and stayed on. And the engine started running really rough. Not a good sign just a week before a really long trip.
By the time I got home it was really running bad. Wouldn't idle half the time. And grey smoke out the tailpipe.
Pulled a code, it said 17. Looked to see if there was anything obvious in the engine compartment, but didn't see anything wrong. Did see that it was the original O2 sensor, so I bought a new one and put it in. Started it up, and seemed to run fine.
Next day, driving to work, about 15 minutes into my drive it did it again. Pretty much the same things.
Don't have a lot of time for diagnosis, So starting to replace things one by one. Ordered a new water temp sensor last night, will pick it up today after work. And yes, I think I ordered the right one. It's the 2 wire one on the right side of the dist.
Anyone have any pointers on what else could be wrong? What to check for, or what might be failing?
Thanks in advance.
Thanks in advance.
