I was wondering...because i get a little paranoid even though it takes common sense to tell when you're driving too fast. All I have is my tach b/c my speedo's busted. uhhh, yea. Whats the mph around 2k rpms and 3k rpms in 5th?
3000rpms in 5th=what speed?
This applies to my 3rd gen so it may differ somewhat from your car.
2K rpm in 5th gear = 45 MPH
3K rpm in 5th gear = 68 MPH02 DX Millenium Red - The Penultimate Driving Machine
~70mph is correct.James G.
sobe83@yahoo.com
AIM: DVS 323BPT
MySpace
Cardomain
<BR>
<marquee>Turbonetics T3/T4, RC 550cc injectors, Walbro fuel pump, SSAutochrome Miata manifold, Tial 35mm wastegate, large FMIC, Apex-I SAFC, GReddy Type S BOV, 2.5" aluminum charge pipes, NGK plugs/wires, RX-7 VAM, 3" turbo-back exhaust, ARP head studs, H&R Springs, S/R struts, Sony XPlod deck-2/12" subs, Power Acoustic 800w amp, Pioneer speakers, Evo front bumper, ADR DV8 17" wheels.</marquee>
3k rpms is between 55-60 mph. i know this ebcause i have all the rpm-mph relationships memorized because i do not have a speedo. when i replaced the first one i broke i went out and made a mental note of the rpms that equal all of the mahor speed limits.
examples :
1st gear @ 4000rpm = 15mph
2nd gear @ 2000rpm = 25mph
4th gear @ 3700rpm = 40mph
5th gear @ 3200rpm = 65mph
5th gear @ 3500rpm = 70mph
5th gear @ 3900rpm = 77mph
5th gear @ 4100rpm = 80mph
5th gear @ 7200rpm = youll just call bs so forget it!Serenity's Dead.
well that depends on what tranny you have 2600 = 65 for me, but i have the cheap ass sohc "F" tranny with the taller 5th gear.When you turn your car on... does it return the favor?
Originally posted by goldstarYes, still have it. It was my attempt to immortalize you in verse.
A Protege driver named Brock
So his engine he goosed
With much too much boost,
Originally posted by taillandit doesnt only depent on the tranny, also on if the clutch is alright or slippery...When you turn your car on... does it return the favor?
Mine'll hit about 120 in fourth... then fall on its face in 5th
I replaced the speedo cable in my Pro a couple days after I bought it... Rader Mazda (stealership) wanted $65 for it... I got it from the local junkyard for $20 and hooked it up in the parking lot For those that don't know... you can connect/disconnect the speedo cable from the gauge cluster without removing the gauge cluster, just reach your hand (or girlfriends if you have big hands) up behind the dash and yank it off._________________________________
'12 Focus SE hatch
'04 Eddie Bauer V8 4X4 Explorer
'05 Saab 9-3 turbo (sold)
'90 Mazda 323 GT (sold)
'04 Mazda Tribute (sold)
'92 Mazda Protege LX (sold)
'91 Mazda Protege LX (blown engine)
'91 Honda Prelude (totalled)
'91 Honda CRX SI (sold)
Tai didn't say which tranny he has.
BruceLast edited by bruce95fmla; 04-15-2004, 04:42 PM.
If it is the car he had last year at the kent meet it is a DXWhen you turn your car on... does it return the favor?
