Originally posted by red90protegelx
Project Protege
i think he meant before the vaf as in closer to the throttle bodysponsored by www.protegegarage.com
i meant in his wording. its not incorrect if you read it as positionsponsored by www.protegegarage.com
Originally posted by red90protegelxi meant in his wording. its not incorrect if you read it as position
Originally posted by 323ForewordI'm using the 1.6 323 distributor. I don't know if there are any gains because I never took the car to the dyno. The best I ran is 15.7 at 85 60ft 2.4 car runs all day 16.0 with cheap used tires 18psi and stock muffler.
Anytime, Mazda 323 with 1.8 DOHC and GT tranny, performance clutch, 2 1/4 piping, Falken Ziex-512, Acura Rims, rotors on all four wheels, front/ rear sway bars, bushings, B+G springs, KYB struts, strut bars... Lightened flywheel. Many top secrets under the hood, "sleeper Mode".
Pass by Nor Cal...Last edited by WTF; 05-21-2004, 10:51 AM.
Originally posted by WTFAnytime, Mazda 323 with 1.8 DOHC and GT tranny, performance clutch, 2 1/4 piping, Falken Ziex-512, Acura Rims, rotors on all four wheels, front/ rear sway bars, bushings, B+G springs, KYB struts, strut bars... Lightened flywheel. Many top secrets under the hood, "sleeper Mode".
Pass by Nor Cal...
