what kind of paint do i use to paint my calipers? engine paint or just regular paint?? or is there special paint i need?
caliper paint
caliper paint
More InformationTags: None
Originally posted by redfoxwhat kind of paint do i use to paint my calipers? engine paint or just regular paint?? or is there special paint i need?
i have a can of 300degree red paint any idea of if it will work?91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
Originally posted by DaProAutozone sells a specific caliper paint, $7.99 a can its 900 degrees, I used a can of 1200 degree engine paint that worked great and it cost $3.99 a can94 Protege DX SOHC 1.8l 5 Speed
(DaPro)
its better to wait and save then to waste money on crap to get you by....
I used caliper paint that I bought for about $7 a can. Have had the calipers painted for about 2 years now and the finish hasn't faded at all. I think it's made by Plasticote, which you should be able to buy at your local Autozone or Pepboys.-------------------------
'91 LX
'03 Mazdaspeed Protege #235
The G2 system is a complete kit containing the paint, brake cleaner spray, mixing cup and stirrer and an application brush. That's one of the reasons it's more expensive than the other alternatives.
02 DX Millenium Red02 DX Millenium Red - The Penultimate Driving Machine
lol last time i went to walmart they were over run in there "huge car audo section" with mexicans HAHA.....some guy spend like 400 on stero stuff and i was changing my oil in the parking lot when he got it hooked up and it sounded like absolute ****, lol and the best part is, i had my subs off and had more bass then his walmart 12's HAHAHA91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
what kind of subs are you running?91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
Why the **** do you need paint thats good for 900 or 1200 degrees??
Most brake fluid boils at way less than 900.
****, we're not driving down the Mulsanne straightaway at 200+ MPH and then braking hard for a corner here people.....
You really think people are gonna say H3Y Th0s3 c4l1p3r5 l00k m4d tyt3 y0 when you've boiled your brake fluid and are heading towards a cliff and can't stop??
_________________DOT 2___DOT 3___DOT 4_DOT 5
Dry Boiling point______374___401_____446_____500
Wet boiling point ___________284_____311_____356
Let's look at some popular brake fluids and their boiling points:
______________Fluid_____DRY___WET
Castrol LMA DOT 3/4_____446 311
Ford Heavy Duty DOT 3___550 290
ATE Super Blue Racing____536 392
ATE TYP 200____________536 392
Motul Racing 600_________585 421
Castrol SRF______________590 518
Performance Friction_______550 284
All numbers are in degrees Farenheit
So you see, your brake fluid will have boiled and you'll have crashed long before your calipers get hot enough to necessitate the use of 900 degree paint.
Face it, driving on the street your calipers aren't going to get that hot.
Probably not even with heavy duty auto-x will they get that hot, and even if they do, you're driving at one for what 90 seconds tops??Last edited by midnightblue97; 06-01-2004, 07:38 PM.Ryan The middle child is always ignored
