15.9 @ 82mph
    Originally posted by 1990DX
    isnt 12:1 a bit much? you didnt mention cams or balancing the crank/pistons (balancing isnt even expensive) but you should look into that probably otherwise it will be a waste having that much compression.
    12:1 a bit much?? Naw, thats where the fun begins. As far as cams, when I said headwork, I meant cams as well. Like I said tho, Bp's have been proven to make like 400hp on the stock bottom end, so Ill prolly leave my rods and crank stock. But I dont plan on making anything near that, so I'll prolly be fine.
    Eat ****.
      just remember the weakest link on the bottom end is the rod bolts.....i'd play it safe and get some arps..
        Originally posted by Gen1GT
        I know I've listed this before, but here I go....
        Cams(260 or 270 duration, 9.5mm lift range)
        Ported and polished head, 3 angle valve job, radiused seats, cc'd chambers
        Eibach valve springs, aluminum retainers, possible bucket/shim conversion
        10:1 pistons, balanced and slightly lightened.
        Rods lightened, polished, balanced and shot-peened
        Block magnafluxed, bored .020" over, decked(need to take measurements before knowing how much)
        Crank lightened, knife-edged, and balanced to 10,000RPM
        Greddy E-Manage w/ 300cc injectors
        Mildy ported and polished intake manifold(possibly custom piece if stock one is too restrictive)
        Intake gasket/port matching
        Bored throttle body
        Custom intake
        Custom header
        Custom exhaust
        Hmmm, did I miss anything? Budget is $11,000Cdn
        standalone ECU
        cold air intake (ghetto hood scoop style)
        but really, that sounds good. you might want to bump the compression up a little more because thats what makes it rev quicker. you can do 10.5 or MAYBE 11 on premium. my car is 10.5:1 (not the protege obviously) and it pings on cheap gas but with 92 it runs fine. more compression than that is bad because you either need a lot of octane additives or you will need to buy race gas at the track or order it in barrels
          standalone ECU
          I'm going to be running 12:1 compression, with a shaved head(44cc chambers), .020" head gaskets and .020" deck hight, along with the 10:1 pistons. I'll see how it runs, then decide what kind of fuel I'll need, and what kind of timing to run.
          Also, I don't want to sacrifice ANY drivability, so that's why I doing the stock ECU/E-Manage thing. I can control initial ignition advance with the distributor, and the E-Manage can control all my fuel needs.
            not running on pump gas is something i would consider as sacraficing driveability but good luck with that.
              I'm sure drivability will be fine, and with longer duration cams, 12:1 on 94 octane is reasonable. If not, I'll buy some toluene in bulk!
                woah thats cool you guys have 94. all we have here is 92.
                  i ran a 10.4 @ 77mph in the 1/8. by my math that gives me a 15.6 in the 1/4
                  Serenity's Dead.
                    my 15.5 was a 10.002 @ 70mph in the 1/8th
                    NEUMAN
                      Ya, your math seems to be wrong. Because with my 15.7 run, I ran 10.049 in the 1/8.
                      I'd say 16.2 with a 10.4.
                      and oh ya, it's impossible for you to do a 10.4 @ 77mph in the 1/8. It must be 67. 77mph and you'd be in the 9.4s 1/8, or low 14s 1/4.
                        There are no Sunoco stations around you??
                          nope.
                            ive got the timeslip around here somewhere, want me to scan it?
                            Serenity's Dead.
                              Yes please.....
                              Also, see what cars run which put down 77mph through the 1/8
                                i remember thinking i did something different that run, but i dont remember what
                                Serenity's Dead.
