trailrider098:
well the reason i have the block is because its got some pitting in the side wall in order to use it id have to sleeve it,
running 40psi isnt a walk in the park the stresses of doing that will be so massive the block wall will just get glowingly red hot, however metal expands when heated so sleeving creates a "safeguard" as you may say against the engine self imploding, also the lighter the bottom end is the higher the car can rev being 1700cc you save some weight,
a fully custom mazda bp engine capeable of doing 11,000rpm launches at 40psi "priceless" finding a box to support that "expensive
Sorry, but r u retarted? ,Y would you convert a 1.8L BP engine to a 1.7L by sleeving a already cast iron block???? where do u expect to get pistons for this and what do u think u are gonna achieve by doing this?***************
