Originally posted by heinze.ketchum
View Post
Parts interchange database
Hey all, long time-no post. Winter is coming to an end and I guess it's time to start worrying about my little car again! mazda1993, I tried putting 00 P5 fronts on my GTR, with no luck. The springs rubbed on the side of the car when I set it down so I took them off right away! I figured they didn't centre the same. But they should be the same shocks as you already have on yours correct? Was I too hasty taking them off or did I screw something else up?
Maybe I put the right side on the left? would that matter?
Thanks in advance everyone.
I'm guessing he's running a coilover sleeve kit on his GTR, so he probably cut off the OE spring perch to make more room.
edit: generally left and right front struts are the same, but flex line location will be different.Last edited by Mazda_Powered; 03-12-2013, 11:51 AM.-Jack
were your old GTR struts damaged? or just a blown seal? Ikd if I've mentioned this before, but you could always get an insert from Koni.-Jack
GTR rear brake pad is the same is 1st gen RX7, but I don't know if they shared calipers or hubs or bearings. All the BG protege/gtx/r use the same big strong wheelbearing front and rear, least as far as I know.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
2wd BG has its own different wheel bearing for the rear I think.1990 Protege 4WD
1 3 5
2 4 R
Originally posted by madaz12a View Posthi there do you know if I buy a aftermarket short shifter for a mazda 323, mx-3, protégé, eunos will fit the mazda 1990 mazda familia gtx.??sigpic
1992 Familia GT-X
1988 323 GTX
2011 F150 Lariat Ecoboost
2014 Civic Touring
