I may be wrong, but AFAIK the viscous center diff (BPT G25MX-R) is basically giving the front wheels all the torque until there is slipping at the wheels. Are there any options to distribute the torque to the rear wheels in normal driving conditions. Might it even be possible to lock the center diff to basically get a permanent 50/50 torque distribution front/rear if the same front/rear gear ratios are used. I'm not sure if that would be desirable though.
G25MX-R center differential options
Well I've pulled up some info on this type of thing:
The 1G and 2G Center Diffs are the same as far as operation and welding goes so this mod works for both.Welding the Center Differential can give you a couple of advantages on a DSM. It effectively locks the power transfer at 50/50 to the front and rear. It also eliminates some inherent...
Sounds good to me.
It is, the centerdiff always sends torque to the back.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
A 43% front/57% rear is a perfect split. The car naturally will have more traction in the back when the car "launches" and the weights shifts to the back when the front lifts up and the back hunkers down. So sending more power to the back and less to the front is genius. Thumbs up to Mazda! It's just too bad they made everything a little on the fragile side.Tyler has spoken
Okay, well that's pretty sweet then. Maybe that's the case with the non-viscous center diff then. Now, what is the deciding factor with the torque split? I read somewhere that the diff ratios determine it. Not quite sure how that works though. 57% to the rear does sound like a pretty nice setup.
And BTW, hey Nerd, nice to come across another ff.com member.
Same screen name. Right now I'm gathering the pieces for my B6T swap (Rustiva). Then I'm looking to go AWD with BPT (Raltiva). Just doin some research on it in the meantime. I'll have to pull up your build thread over at ff. There's an AWD Protege near me for $1000 I'd love to snatch up, but all my cash is goin into my current projects.
The front & rear ratios are not the same so locking the diff full time is NOT good for the drivetrain, both BF gtx & BG gtx transmissions1991 Capri XR2 "GTXR2" BPT AWD Bastardization/conversion
Creator of the B6T Rocketchip
www.werbatfik.com
This page says differently: http://www.protegefaq.net/transmission.html#G25MX-R
BF front FDR: 4.388:1
BF rear FDR: 3.909:1
BG GTX front FDR: 4.214:1
BG GTX rear FDR: 3.909:1
Is this info incorrect?1991 Capri XR2 "GTXR2" BPT AWD Bastardization/conversion
www.werbatfik.com
My GTR service manual says front is 4.214, and rear is 3.909. Which I don't understand fully. The car has the same size tires, but different ratios for the front a rear axles. Would one set of wheels not constantly be slipping then...? I don't have anough experience with AWD yet.Tyler has spoken
The front will spin faster than the rear. The center diff, being open or viscously coupled, will slowly rotate to make up the difference.
It'd be like going around a turn in a FWD car, the spiders in the diff will rotate slowly due to the different rotational rates1991 Capri XR2 "GTXR2" BPT AWD Bastardization/conversion
www.werbatfik.com
