is that on your car??
brembo conversion?
More Information
Originally posted by MazdaRacerno, i think it's a dude from the UK who did the conversion.-------------------------
'91 LX
'03 Mazdaspeed Protege #235
Originally posted by 92_2_fastLink? I have flushed the brakes, am running potenza 950's, just resurfaced rotors and am using oe pads. But from sixty mph I would like to be able to lessen my stopping distance. I realize that the oe set up will lock them up,...blah blah blah"Never run out of real estate, traction & ideas at the same time"
-93 MR2, 129 ES
ClubProtege.com Tech Articles
Yes I realize that skidding is not the fastest way to stop. I will NOT argue that with you. But track proven evidence shows that larger brakes slow a car down faster WITH OUT locking up the tires. All I was saying was that the oe set-up has the clamping capability to lock up the tires. SO until you understand what I am saying DON'T critisize. And thank you everone else for the info. That picture of the conversion was just what I was looking forToo bad I have AWD and you don't!
I honestly don't understand how that would work. Please elaborate on this "track proven evidence".My ClubProtege.com Feedback Thread
MOSI Race Dynamics - Aftermarket Parts Sales & Services MOSI Race Dynamics Feedback Thread
Originally posted by mike_mossI honestly don't understand how that would work. Please elaborate on this "track proven evidence".91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
They were talking about straight up stopping distances...how would that help?My ClubProtege.com Feedback Thread
Originally posted by charlesNASCAR also has some big damn tires which they change every few pit stops. Also, the rotors are huge, because things get damn hot in an environment like that! Something a Protege will never see...91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
Originally posted by mike_moss91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
Bigger rotors = more cooling = better braking.
If your have a 13" rotor it will have more time away from pad contact than a 10" rotor would in the same situation. Better heat dissipation will bring better, more consistant braking performance.
As far as larger calipers.... they're more of a "bling bling" mod unless you're upgrading from some truely ****ty brakes, the stock LX 4-wheel disc is more than enough with some performance pads and well maintained rotors. My $.02_________________________________
'12 Focus SE hatch
'05 Saab 9-3 turbo (sold)
'90 Mazda 323 GT (sold)
'04 Mazda Tribute (sold)
'92 Mazda Protege LX (sold)
'91 Honda Prelude (totalled)
'91 Honda CRX SI (sold)
one could also argue:
bigger rotors = more heated metal = longer heat dissipation
changing the size of the rotors does not change how fast they cool. If anything it makes it worse, since there is more metal. Thats what the cross drilling and slotting is for.
It really depends on the use of the rotors, and how they are going to be used. Street power every day breaking.... the oem **** is good. If you are a hardcore Auto Xer, or want your car to look pimp then go with the conversion. Hell I would do it for looks as well as function even though I am no hardcore racer.
Still, the conversion is pointless unless you just want huge brakes or you are road racing.
Autocross does not require brakes like that. You barely heat them up in a run!My ClubProtege.com Feedback Thread
