endlinks are truely personal preference..... superpro endlink kits are just bushings
Polyurethane replacement bushings list.
Didn't see it listed in this thread but Energy Suspension parts can be special ordered through AutoZone. LCA set is $29 and trailing arm set is $33. Just tell them you are looking for bushings for a 98 Ford Escort. They cost a couple of bucks more than some online places but there is no shipping and you will have them in a few days.1990 Protege LX
2002 Saturn SL1
My Protege with 182k miles on it runs better than my Saturn did new!
great find!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by scortadict View Postso what the easy way to order superpro bushing?? i'm ready to order some for the 323.
If I shouldn't be posting this, feel free to remove it. Just got a bump email as I'm still subscribed to this thread.My ClubProtege.com Feedback Thread
MOSI Race Dynamics - Aftermarket Parts Sales & Services MOSI Race Dynamics Feedback Thread
Originally posted by mike_moss View PostWe carry SuperPro. Doubt the 1st gen stuff is in stock, but if anyone would like to shoot me an email (Mike 'AT'' MOSI ''DOT' ca) you're more then welcome to and I check stock for you.
I wish I knew this too...I would have rather supported a canuck operation . I just ordered up all Super -Pro the bushing to do both the front and rear end on my 323 BG.
You show you carry Ground Control coil overs ... whats the cost on a full set up of adjustable coil overs for a 1990-94 323 hatchback ?
Oh and Viper _707 ... do you still want the fender /door molding off my GT ?
If I shouldn't be posting this, feel free to remove it. Just got a bump email as I'm still subscribed to this thread.2012 Kia rio
2009 Nissan Frontier
1997 chaparral 180LE
So i don't think i totally get the way the bushings are. I wanna replace everything with good quality stuff. have heard great things of SuperPro... so... is this a good list of parts...? the sizes i'm not sure of. the parts on the car are stock.. all besides the mx3 tie bar lol... and its for the 4wd if that makes a dif..
Front Lower Control Arm (oilpan side)
SPF0952-90k Sport-90 duro "38 mm outer diameter bushing" -$40
Rear LCA Bushings
SPF0953-80K Standard alignment Sport-80 duro "35.5 mm outer diameter bushing" -$38
EndLinks
SPF0903K- swaybar endlink -$19
Frame Mount Bushings do i need front AND rear???
Front- SPF0908-_ _K "insert measured bar diameter 19,20,21.5mm available"- $16
Rear- SPF1406-_ _K "insert measured bar diameter 20mm available"- $16
Rear Trailing Arm Bushings do i need front AND rear???
SPF0907K front bushing-80 duro "40mm outer diameter bushing" -$42
SPF2744K rear bushing-80 duro "44mm outer diameter bushing" -$53
please note, i wanna replace all possible.. and i think this is it from the list provided...1992 Ultra Blue Metallic EGT - The 'scort with no name - crap>reliable daily>rallycross prep>stage rally
Jason, PLEASE PLEASE note: i've found 4wd parts to be of different measurements then FWD applications. you must measure the bushing diameter to confirm correct fitment. (blame mazda for mismatching things)
Figured i would give you a heads up so you wouldn't place a parts order for the wrong bits.
In the end please post your dimensions & i will update the list.
Ryan---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
hey guys, I'm reviving this thread. I know a company that makes plastic stuff and the moment they are figuring out if they're capable of making PU bushings.
how can I get an appropriately sized bushing? Should I take a OEM rubber one and take it there so they just copy it? Are there any dimension or diagramas for second gen?
what about the metal sleeve? can reuse the old one? do the have to cast the polyurethane over the sleeve or can it be inserted into the bushing later?
thanks pplGarage: Mazda Protege 1995, Z5 engine, MTX, P/S, no A/C, no ABS.
PM me if you need: comprehensive Autodata information; Mazda's 2nd generation workshop manual; Mazda's Z5 overhaul workshop manual.
I forgot to say that besides casting I'm more into cutting the pieces out. making a big PU block and then cutting it out with a CNC could be much easier than making molds for casting. what do you think?Garage: Mazda Protege 1995, Z5 engine, MTX, P/S, no A/C, no ABS.
screw poly..... have them make delrin or nyoil bushings for the LCA's & TTL's---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
you threw my ambitions and excitement right into a pile of cow ****.
so you say nylon? I know delring is somehow affected by chlorine and it can be easily collected on the road ...
I think nylon is a good option since it's a massively used material. I'll ask them that too. this applies only to arm bushing? what are nylon swaybar bushings like?Garage: Mazda Protege 1995, Z5 engine, MTX, P/S, no A/C, no ABS.
NYOIL!!!! not just pure nylon. wikipedia it.
Poly is a good replacement & will last for several extremely hard driven years before showing any signs of wear @ all.
my statement was basically from a standpoint.... im ready to go to the next levelthats all.
