I can't remember the stock front size, but the ST front bar is an ADD ON 19mm bar. Meaning you leave the exsisting one there, and ADD another. There are some small binding issues, but not enough to get into a fuss about unless you're a stickler for "ideal" things...and then you're looking custom and a lot of labor to install it.
Originally posted by deadly_sleeper speaking of sway bar sizes, how big is the mx-3 front sway bar? and how hard is it to get it on our cars, if possible?
also how big is the rear sway bars on the LXs?
thanks
MX-3 bars are NOT interchangeable. The ends are rotated 90 degrees from ours.
Stock LX front bar is 22mm, rear is 20mm, later models had a 21mm rear bar, i think it's 90-91 and 92-94.
Stock front bar on a ZX2 is 25.4mm (1") and is interchangable, but changing the front bar, means dropping the entire sub frame and suspension, along with the lower crossmember, so an engine support will be needed aswell.
Also, unless you get a 1" rear bar (or bigger) to match it will have lots of understeer.
all the rear bar's are set at one standard...
or so the book says (including the 323)
rear-20.0mm(0.79)
if these are correct measurements and all...then the ZX2 bar isn't technically much bigger in the front then it looks...(it looks to be a good 4-6 mm bigger when placed next to the stock LX bar)
god thats a bitch to install the ZX2 bar onto the 323.....(just ranting)
very small changes in sway bar diameter change the stiffness of the bar greatly.
I think you could get away with this, just as a lot of stock class autocross cars do.
Big front bar = less body roll
less body = less body roll induced positive camber
less body roll induced positive camber = more front end grip
more front end grip = less understeer.
it's a theory that works with SOME cars. I think it could work for a BG chassis. On another note, since the BG chassis cars don't have issues with putting down power, unlike for example, the 3rd gen guys, I think a big front bar wouldn't have a lot of bad side effects.
Out of curiousity, are the GTX or GTR sway bars swappable? I remember reading somewhere that the GTX has a 22mm front sway bar and the GTR a 23mm one. If they are in fact interchangeable, wouldn't a GTX(R) front sway bar and an ST rear bar make a good setup?
Originally posted by Identity_X Out of curiousity, are the GTX or GTR sway bars swappable? I remember reading somewhere that the GTX has a 22mm front sway bar and the GTR a 23mm one. If they are in fact interchangeable, wouldn't a GTX(R) front sway bar and an ST rear bar make a good setup?
It would probably fit. Same PITA install as the ZX-2 bar. No point in putting the 22mm bar in an LX though, since that's the stock size. And using the 23F/22R (ST-size) wouldn't have much of an affect on the handling balance, but would reduce body roll somewhat.
And the '92 and later LXs are the ones with a 21mm rear bar.
David Avard
'90 Protege LX (STS-prepped)
'89 Civic Si (STS-prepped)
'02 Altima SE (14.164 @ 97.7mph stock)
