is there any way to change the drop-links to end links on the protege to fit the mx3 swaybar??
Drop end links from Mx-3 on my 323???
there is sway bars available for the 323, are you looking for a front one, or an upgraded rear?"Discontent is the first necessity of progress."
all depends if the MX3 LCA's will bolt onto the protege properly, if they will then its a plug & play job.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
