Im thinking about ground controls but i havent heard much about on here. If you have them, whats do you think about them and what shocks are you using. Do they handle well? 2 hard? 2 soft?
Who has Ground Controls, how do u like them?
zx2 + ground controls. and you can get them custom at ANY spring rate you wantsponsored by www.protegegarage.com
i have the ground controls and tokico s/r struts and the ride is very stiff and hard. I also have 17's with low profile tires so the ride seems extra hard an stiff on bad roads. In my opinion its a bit to stiff and hard for daily driving. (i also drive with the coils all the way up)
2004 Subaru STi
1995 Subaru Legacy L. DD
1993 Mazda MX-3 BP-T sold
91 Escort GT- BP-T R.I.P
ok, i like them. and you can get them at ANY SPRING RATE YOU WANT - i.e. harder or softer. there is a 100% chance everyone on here has a different spring rate - every set on ebay is different, and if you buy from the site you have to specify. what about that doesn't answer your questionsponsored by www.protegegarage.com
i swapped out whatever mine came with for my friends 450# f/r from his p5. body roll?sponsored by www.protegegarage.com
Originally posted by OCD-SPEEDIm thinking about ground controls but i havent heard much about on here. If you have them, whats do you think about them and what shocks are you using. Do they handle well? 2 hard? 2 soft?
I was going to use ZX2's with them, but I decided I just wanted to use lowering springs instead. After being unsatisfied with the drop, I bought Weapon R coilovers. I have them all the way down on ZX2's. Its a very harsh and bumpy ride. I know for a fact that my rear struts are blown, the fronts probably are too. Its hard to tell though, because when your that low, you're not even using your struts. The guys at work say I look like a bobble head doll when I'm driving.
Anyways, the ground controls were much nicer looking than the weapon r's I have now. If your going to use the ZX2's, get a mild spring rate.
