Its definatly the rear right, I sourced the noise out.
I am happy.
The Car:
2003 Mazda Protege 5
- Injen Intake
- Meagn Racing Cat-Back
- 17" Enkei EVO 5's
- More Goodies to come....
The System:
Head: Pioneer DEH-P6000
Components: Infinity Kappa 680.7CS
Amp: Kenwood KAC-5203
Sub: RE Audio XXX 15"
Box: Custom built 4.4cu. ft. Tuned to 27Hz
Amp: HiFonics Brutus BXi 1606
Originally posted by NitrousIts definatly the rear right, I sourced the noise out.
You can jack your car up and wiggle the wheel side to side to check the RR wheel bearing.
What kind of noise are you hearing?
Its a vibrating/buzzing type noise. I am probably going to take care of it soon... it is driving me nuts sometimes, other times its not so loud.The Car:
- Injen Intake
- 17" Enkei EVO 5's
The System:
Originally posted by NitrousIts a vibrating/buzzing type noise. I am probably going to take care of it soon... it is driving me nuts sometimes, other times its not so loud.
Yes the noise gets louder when I turn left, and gets quieter when I turn right... therefore its the right side correct if sitting in the driver seat or looking at it from the back right?The Car:
- Injen Intake
- 17" Enkei EVO 5's
The System:
Originally posted by NitrousYes the noise gets louder when I turn left, and gets quieter when I turn right... therefore its the right side correct if sitting in the driver seat or looking at it from the back right?
There are occasions where it will work the opposite though.
If it is that bad, then you should be able to hear which side it is coming from. If you can't tell, have a friend ride in the back seat while you drive.
Originally posted by JhoUsually a wheel bearing that is bad will howl when you put the weight of the car on it, that is by turning and shifting the weight on it.
If it is that bad, then you should be able to hear which side it is coming from. If you can't tell, have a friend ride in the back seat while you drive.The Car:
- Injen Intake
- 17" Enkei EVO 5's
The System:
