Supp, i'm starting to build my '93 323, it will be a street legal car but mostly for drag racing, meaning no interior at all, complete strip down, etc. I'm looking for a good suspension set up; whoever have parts let me know i still need a couple of things and any comment or knoweldege will be more than welcome, sooner i'll be posting some pics of my lil underdog, thanx Alex
Hey Alex,
Welcome to Club Protege.
Just a suggestion for you, it would be easier to read your post if you kept the typing simple................no bold or colors. Thanks.
How low do you want to go?
For struts, I'd recommend the popular Tokico S/R struts from a '97+ Ford Escort ZX2. They are the best bang for the buck, and the ride is pretty decent. The rear struts are plug and play, and to use the front struts, you need '97+ Escort upper strut mount bearings, and upper spring perches, or you could modify your 323 upper spring perches to fit the Escort bearing.
Well the website didn't say its specified for OE springs, anyway I don't do high performance driving or over-drive my tires traction capability. I like Koni struts, but there a little expensive. But hey, it beats Grabriel original equipment. But this combination turned out good, if you want a euro style handling and ride without breaking the bank. Even though european suspension is a little stiffer and can be sometimes uncomfortable.
But I got the KYB struts for $48-51 a strut, which is a good price last year. But when I checked the website that I ordered from the price went up.
Originally posted by Silentbob343
KYB GR2 are OE replacement struts and are made for OE spring rates.
I just wanted to throw that info out there. I actually emailed them a while back when looking at struts and that was their response. My question was what spring rate should be used with their GR2 struts.
