Backs up my theory they are just the Escort lines.
Where can I get SS brake lines?
the part that mounts to the frame on that little tab.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
tirerack has goodridge lines that are approved by just about every continent worth living in dot, iso9000, tuv etc. 65 bucks, i got them for my mx3 but its the same for the bg protege.
btw, cs lines are only "dot quality" not really dot certified. goodridge lines are made little bit longer than oem lines so that at full suspension droop and full compression the lines will not have to stretch or tear at critical moments. someone on mx-3.com had a busted corksport line, luckily he is alive.Last edited by steeb; 07-18-2006, 07:13 PM.
Originally posted by steebtirerack has goodridge lines that are approved by just about every continent worth living in dot, iso9000, tuv etc. 65 bucks, i got them for my mx3 but its the same for the bg protege.
btw, cs lines are only "dot quality" not really dot certified. goodridge lines are made little bit longer than oem lines so that at full suspension droop and full compression the lines will not have to stretch or tear at critical moments. someone on mx-3.com had a busted corksport line, luckily he is alive.2005 Mazda 3
I believe the MX-3 lines are different then the Protege lines. They will work though , just mount a little different.c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
