ok so i take my 90 es down the road yesterday and i go to stop and the pedal is hard to push. so i apply more pressure and the pedal gives to about half way. the car stops but the brakes are still stuck there. also similar thing happend when i pulled the ebrake. whats wrong
seized brakes
sounds like your calipers are siezing up on you. check your slide pins
also check to make sure your hose to the brake booster is good, if so do a check on the brake booster you may need to replace it.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
the slide pins are part of the calipers... if your unfamiliar with how to service your brakes please seek professional assistance as it can be your life @ stake.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
The slide pins are what your calipers ride on and allow them to move when you hit the brake pedal. Goto your local auto parts store and purchase some new calipers and pads. While your at it check the rotors for warpage and inspect the brake lines for damage.
Or better yet order new Calipers , pads , rotors , lines and brake fluid and overhaul the whole system. Then check the e-brake cables to make sure they are not siezed.
Has this car been sitting for a long time in humid conditions?c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
and if its stuck like hell and you just need to get it moved get a can of PB catalyst rust penetrant and nuke em, then take em with a hammer (gently!) or the end of a ratchet (something hard and metal). i had this happen on an old maxima i bought. . . after the above treatment it was fine.sigpic
Originally posted by southerncrossand if its stuck like hell and you just need to get it moved get a can of PB catalyst rust penetrant and nuke em, then take em with a hammer (gently!) or the end of a ratchet (something hard and metal). i had this happen on an old maxima i bought. . . after the above treatment it was fine.
actualy, the correct way would be to heat them & knock them out, then do as you said Jho---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
well if your calipers are siezed your ebrake wont work being that it uses the same brake as the rear brakes.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Originally posted by purewhitemp5The slide pins are what your calipers ride on and allow them to move when you hit the brake pedal. Goto your local auto parts store and purchase some new calipers and pads. While your at it check the rotors for warpage and inspect the brake lines for damage.
