Hello Folks. Could anyone tell me in which direction should the front strut mount be facing i.e. in what direction should the side with the notch be facing. Thanks
I want to say that that notch faces the inside of the engine bay, so the two notches would face eachother...................I know that's where the little rubber tabs go anyways.
Thanks a whole lot. You guys are the best . bpt323 where did you find that diagram? I knew I saw it some where before I just cant remember where. OH and the best way to get answers is to ask everywhere.
what exactly does 14' or 29' mean? its not degrees... is it hundredths of a degree??
would 14' of +camber be worth the 14' change in caster?? we must lose SOME camber when we lower the car... i know you are a big fan of the caster ryan, but i forget if it was positive or negative.
-jon
i took a snap shot of it from the PDF just for you. Im a nice guy like that.
Thanks a whole bunch. I was changing the front struts and I replaced them inthe wrong position. I had a nagging feeling that I did the wrong thing. Thanks for clearing that up for me. Where can I get my hands in that PDF? Is it available for download?
That measurement is in "minutes". It's another way of measuring less than 1 degree...60 minutes = 1 degree. So in this case, 29 minutes is about 1/3 of a degree, and 14 minutes is about 1/4 degree.
