When installing the front struts, the mounting plate can be rotated for different camber caster angles. In the FSM, there are 3 positions that are shown with the associated camber and caster degrees. But it doesn't show the camber and caster angles for the basic position, where the direction indicator is facing the engine. In that position, caster and camber are both 0 deg or no?
Thanks
Thanks
