im looking at 16's for my 93 DX. will they fit no problem? and im sure they wont, but what about 17's? will they fit
very stupid question, easy answer...
Yes and Yes. The offset is the most important part, though.
17"x7" +40mm fits fine on my 323 with a 205/45/17 tire.Dan
dreesemonkey
Oh yea, and if I were to do it again, I'd get 15x7" kosei K1 racing wheels. Cheap and light. My 17s are light, but they are still A LOT heavier than stock.
If you're looking to make your car sportier, don't bother with 16s or 17s. Trust meDan
dreesemonkey
You have to be a bit more specific. What width are we talking about? 16" and 17" wheels will fit as long as the width and the offset of the wheels are proper.-------------------------
'91 LX
'03 Mazdaspeed Protege #235
16" x 7" should fit fine. As for the offset, you should be looking at +38 to +40 or something close to that. Make sure you find out the offset of the whees before ordering them, but most likely they'll fit with no problems.-------------------------
'91 LX
i have 16 x 6 with a 38mm off set
remember the off set is measured from the center line of the rim.When you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
