I tried doing the rear brakes last week, whats the deal, i know the rear brakes sometimes need to be screwed in but the pistons dont have the notches to screw them in is there another method for doing this?? the pistons wont collapse i used channel locks, then C clamp, then C clamp and twist with channel locks, idk what the deal is, it should be easier than this, what am i over looking
rear brake piston stuck
thers a 14mm bolt on the back of the caliper, behind that is an allen key that is turned to adjust the piston---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
uhhh... it says that in all the manuals too...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
??? don't remember than situation, sorry---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I learned that from a Haynes book!1990 Protege 4WD
1 3 5
2 4 R
Originally posted by me109 View PostI learned that from a Haynes book!
I learned that you can rebuild a transmission and not get a smudge of oil on you.
Me VBGarage HERE
"90% of young people that get into car accidents say "OH ****". The other 10% are from Wisconsin and say "Hold my beer and watch this!".
