ya thats a thaught, most of our cng cars around here are in the city from national fuel so its worth a look i guess, they are using honda civics now too , i wonder what those would be...i know those are direct fit but probably would need resistors...
junkyard gems/oem upgrades
^only the older civic's had low ohm's which would require resistors........ however its always safe to double check---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by miK3Pro View Posti been told some people in pr used these injectors, and its from any v8 ford....^have you got the running with them yet?
Originally posted by bpt323 View Postthey dont' run CNG here in the states..... maybe the taxi cab's but those things run forever.
mail me a set92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
KIA BP SERPENTINE PULLEYS.
I had some issues with the V belt jumping off my bpt when i hit the rev limiter. I now have a KIA BP which has 2 serpentine belts and I never seen that problem again. If you make this upgrade make sure to get the right accessories to go with them (alt, p.s.p. ect.)
Also if you already have the Kia Bp or pulleys, The 88-92 MAZDA MX-6 alternator works with those pulleys.
And if the alternator plug gets damaged, most nissans use the same plug.sigpicBACK TO SQUARE 1
upgrading your alternator to anything more then stock is a huge improvement all around---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I don't know if this has been posted yet, but I found out that there's a difference between the gt rear bar and the escort wagon rear bars. The wagon ones are solid, while the gt's and I think all other rear bars are hollow.My family has lots of bg's!
1992 Mazda 323: Race car
^ old information most of the "ancient members" would only know
for a good information repost
Originally posted by bcowie View PostI just did the 90A and I agree with this.94 pro base model, all synthetic fluids, s/r struts, front & rear ebay upper strut bars,front & rear tie bar, ZX2 1" front swaybar, EGT 21mm rear sway bar, custom delrin endlinks front & rear, custom delrin rear swaybar mount bushings, EBC front blanks & redstuff pads, CS ss brake lines & dot 4 fluid, big drum brakes in rear (from ZX2, free parts), 2.25 custom exaust w/magnaflo oval muffler, 4-wire o2 sensor, custom ram-air, 4-wire BP tb, MSD super conducter plug wires, MSD Blaster SS coil, NGK iridiums,OEM weighted shift knob, ebay short shifter, bronzoil bushings, CS ss clutch line, custom air splitter, mx-3 recaro drivers seat, EGT foglight switch, 35w 5000k hi/lo hid's
soon:
lightened flywheel & clutch; in garage,
Miata Daisy's; after new tires
Originally posted by protegemartin View Postwich one did you use? and wich one is the easiest one to use?
You need to change both bolts the one on the bottom goes in the other way and needs to be longer (this is imo a better design)
I beleive it needs to be 130mm long
Bolt on top needs to be changed as well as the alternator isn't threaded, so you'll need a bolt/nut combo.
Pulley needs to be swapped over as well as the washer from the old 65A.
it takes about 20mins to do all of that.
