Ok my BG is an 94 LX with all 4 dics brakes.so you're telling me if i get the 99-03 BJ 5 lug dics brakes all 4 it will work on my 94 BG.(onemore thing do i need to get the hold entire struts with it or just the hubs alone thanks alot).im looking forward for you're help.
How-to; DIY 2 pot brakeupgrade
if you are looking for just the upgrade to 5 lugs then take the hub from one of the mazda cars with 5 bolt pattern and put that hub in your nuckles i know one of them bolts right in just don't recall whichIn the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
The ProjectMx build thread
MyCardomain[/SIZE]
I can't say for sure, but I can say that all models of BG and BJ use the same front wheel bearing so I'm pretty sure that any of the front hubs would interchange. Ther rears are a little trickier because the BJ rear disk brakehub is clearly larger than the drum brake one...which is the same as the BG one for all models. But the spindle is the same for drum or disk brake BJ's so I think that the 5 lug hub will fit on your BG but it won't be known for sure until someone checks.
EDIT: Check that...the BJ with rear drums uses a different rear spindle than the BJ with rear disc...which makes sense. The spindle OD and bearing may still be t he same, but I am not sure at all if the 5 lug hub will fit ont he 4 lug spindle. Someone will just have to try it.Last edited by 300BHPZE; 02-11-2010, 11:48 AM.
yep, auto wreckers re&re ftw-Jack
just as a small update to my original post
i've found that a certain toyota, yet to be named!
has 4x100 275mm x 25mm thick rotors
and basically has the same hat dimensions as the mazda BG
i will confirm fitting shortly (1 month or so)
that alone will stop most any Mazda under 1200 kgs at the track
that alone will stop most any Mazda under 1200 kgs at the track1997 Protegé ES: The Power of BP
Broke Status FTW!
what is the "hub reg" and "bolt size" talking about?In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
Originally posted by projectmx View Postwhat is the "hub reg" and "bolt size" talking about?
Originally posted by Henchman View PostI'm guessing AE101 rotors?
but the normal ae101 are the same size as BG so must be a very close upgrade
hi to all, i have found whats look like a 93-97 626 in my country (very rare to find one over here).
So will the brakes from the 626 work on mine BG? ive read trough the whole thread and didnt get it, my bad
any help will be apreciated
I'm from Uruguay, so my english might be wrong, any mistakes please, correct me
nope will not work, sorry!-Jack
