You would have to make a custom offset balljoint. A custom bracket offset to one side made to accept a readily available off the shelf balljoint to keep the price down. Sounds like to much trouble doesn't it?
How-to; DIY 2 pot brakeupgrade
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Well I broke down and went out and sourced everything to do the swap as it was done by the OP. The cost breaks down like this...all prices in $CDN
323F BA V6 spindles...$110 (I got a wicked deal from a UK member so that was mostly shipping)
EBC MX-3 blank Rotors...$100 (with shipping)
SS Brake lines...$40 (this is half the cost of the set I bought last year)
94' Subaru Legacy Turbo Wagon calipers...$115 ($45ea + shipping from a wrecker in Calgary)
89' MX-6 caliper brackets...$15
Brake pads...$70
Wheel bearings and seals...$80
MX-3 hubs...$20
Misc...$30 (paint for calipers and brake fluid and stuff)
TOTAL: ~$580
It could be done quite a bit cheaper than this. If you got a good deal on the spindles like I did and reused your stock rotors or bought cheap ones, no SS brake lines, reuse your stock hubs...this could be done for $350 or so I think.
I will post pictures when I do the installation.
I also have not given up on the dream of an easy upgrade not requiring the UK spindles. It will require cutting but I'm working on at least making it easy.
pics man!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
just to update as this upgrade was done MANY years ago and i should have updated
option 1 you can use some Honda civic and Integra rotos (262x21) not the thickist rotors but work well and give NO overlap for the pads <-- my current setup front bias is better than my GTX brake setup, 220kg sq vs 340kg sq on the test rollers. rears are 10kg sq less than stock...
option 2 ..use Nissan Pulsar GTiR rotors are they are 257mmx25mm thick and have the same offset as BG rotors much better for option 2 as the calipers are ment for 26mm rotors
Dave
Originally posted by atomicEGT View PostWhy MX3 rotors instead of ones from a MSM?
GTiR parts are not available over here. That would be a great option if I could find them.
After a couple of weeks on the Subaru calipers the pads are nicely bedding in and the car stops like a welder at quitting time. Much better pedal feel adn must less effort.
I am going to upgrade the master cylinder to a Millenia 1" bore unit to reduce the pedal travel, which is a bit longer. The Millenia and MX-3 GS masater cylinders are similar so this is a straight swap with just a bit of re-routing of lines as the lines come out the other side of the M/C. You BG guys would not be able to do this easily as your M/C is quite different IIRC.
I just wanted to point out something that I figured out this week that had never occurred to me before.
In the process of doing this swap I installed new wheel bearings in the spindles so that I could put the 4 lug hubs in place of the 323F 5 lugs. I've done this many times over the years and never had a problem with a bearing but this time I damaged the bearing slightly and I knew it.
I had to wait to replace it because my facilities for this type of thing are limited. It was clear that the car stopped better, but the more I drove it the less impressed I was with the new brakes. Until this week when I finally got to repalce that bad bearing.
Because there was considerable play in the right front wheel bearing the rotor was actually being pushed away from the caliper when I pressed the brake pedal making the whole thing very sloppy. Now that everything is rigid, the pedal is hard and the car stops very very hard. In fact I would go as far as to say that I need to increase the bias to the rear a bit.
Lesson here is...if you are having diminished braking performance and you know that the brake system is good, check your wheel bearings.Last edited by 300BHPZE; 07-23-2011, 09:25 PM.
i should have posted a rear brake upgrade here to to help with the fronts
due to the extra force at the front with the two pots, im now running a larger rear pad from a .......Mazda GE base MX6 , Cronos or Capila in your country
bolts right up to the MX3 caliper mounts that we get here in NZ
made the difference, but im still looking for a 15/16 MC to complete the setup
sadly the car hasnt been driven in a while and the rear calipers have siezed
gona have t oget some new ones now
I have 9.8" rotors and calipers from an 06' Mazdaspeed Miata on the rear and I still find I have significantly more front brake than rear.
The stock MX-3 master is 15/16. I have a 1" master from a 929 Millenia that I want to install but having trouble finding the time. I expect it will reduce my pedal travel. I think I may also go to an aftermarket adjustable proportioning valve.
im still on the hunt for a sufficient 5 lug rear rotor in 10.1" or slightly larger
(so long as i can fit it under 15" wheels)---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
98+ 626 V6 have +10" rear rotors Ryan. I know they come with 16" rims from the factory, but I'm sure the spare is only 15"-Jack
