Hey, I was wondering if anyone knew if the bigger front disc and rear disk setup from a 96 pro lx would work on a 1st gen? It looks like it should by eye, but I'd like to know for sure before I start pulling parts off at the junkyard.
2nd gen brakes on a 1st gen?
96 Lx i don't think has the bigger front brakes does it?? 14-22v?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I forgot to check the number on the caliper, but I thought they were supposed to be the bigger ones for the 14" wheels, I know it has rear discs though.1993 Mazda 323 - BP conversion, Front cross drilled rotors, Front and rear strut braces, Filled motor mounts, Mx3 seats, BPT conversion in progress SOLD
1993 Mazda Mx3 GS Stock for now
the 96 brakes are going to be no larger than the 90-94 10" brakes... and you know for sure that those will bolt up. i'm assuming you have the 9" front brakes on your 1st gen...?
oh i see you are in canada...
look for the 10" brakes on the front of a 91+ escort. those spindles will bolt right up, just make sure you buy ball joints for the year escort they came from. 91-96 escort = 90-92.5 pro, 97+ escort = 92.5-94 pro... as far as ball joints go.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Good to know about the escort 10" fitting for sure, but it would be nice to be able to use the rear discs off the pro lx before they crush it1993 Mazda 323 - BP conversion, Front cross drilled rotors, Front and rear strut braces, Filled motor mounts, Mx3 seats, BPT conversion in progress SOLD
