For those who run R-comps (or whatever), what are you using for your camber/toe settings on your BG chassis? I need to set a baseline for the Tracer. As far as camber settings go, I can get anywhere from 0 to -3.5* on all corners, so adjustment range isn't an issue. The tires are 225/45/14 Hoosiers.
BG Autocrossers: Alignment settings?
i don't run R comp's & im on the light side of camber in front -1.8degrees zero toe
Rear is -2.4degrees with .3 degrees of toe out in the rear to help it track around better with the front---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
