ok, how many bg owners experience this sentence below?
go outside and grab your steering wheel, with the engine running, and rock it back and fourth. can you hear a knocking sound coming from the rack area?
all three of my pros do this, (the dx and the parts car have a slight knock) but the green car is the worst. I have checked the rack bushings, inner and outer tie rod ends, pump belt for wear, pump and rack for leaks, ball joints, and wheel bearings for play or looseness....all good.
Now on to the real problem...
When the road is wet and im going 65-70 on the highway...its dead scary. I feel the front end getting loose and it pulls the car and the steering wheel. It does the same at 35-40mph or so, but its not as bad. At that speed if i turn the wheel right say..5 degrees while going straight, I can feel what seems like a quick shimmy or wobble in the sterring wheel and front end and the wheel just stays there and wont center, turning left the same way feels normal...I dont think the pump belt is slipping. Alignment is ok as well
Im looking for some insight or similar experiences. All posts and help is welcome and appreciated. Thanks!
