Cant put it on a hoist till monday but i've started to loose power sterring fluid pretty fast. all the hoses look good no leaks there. but i look under the car and turned the wheel lock to lock and it seems to poor out during right turns more if its hard all the way right.. u think its just a seal or could there be a line on the rack cracked? just want some opinions. have been getting alot of snow and ice up there so who knows
Steering rack leak?
nows the time to give up on powersteering all together... if you take the rack seals out. its actually almost just as easy as powersteering. taking the belt off or snipping the lines makes it harder then breakign it down & taking the seals out.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Postnows the time to give up on powersteering all together... if you take the rack seals out. its actually almost just as easy as powersteering. taking the belt off or snipping the lines makes it harder then breakign it down & taking the seals out.
that would work too---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
