Are the MX-3 Trailing arms longer or shorter then the Protege's? if so what is the difference? the reason I'm asking is that I can only get new trailing arms from Altrum, but no one else sells them for the Pro's nore just the raw bushings
MX-3 Trailing arms
should be the same---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
The lenght is the same, but attach at the rear knuckle (bushing/shim design on mx-3) is not the same. You can run BG trailing arm with a complete Mx-3 V6/4cyl rear, but you'll need to pry the trailing arms slightly and bushing(s) effectiveness is not at it's max, same for bushing life.]94 Mx-3 GS-R SE, DRD TuningHand built KL-ZE , 4.105:1 LSD. (Built from '96 PGT KL)
1110Kg dry.
"MONEY SHOT"
