does anyone know if the MX-3 front and rear LCAs are interchangeable with the ones from a 90-94 323/protege?
i ask b/c i have a 323 that has the subframe swapped from a MX-3. well i didn't know that when i ordered the rear sway bar, and now the new endlinks won't/can't bolt to the MX-3 LCA, b/c the opening for the endlinks to slide through is much bigger. I cross referenced a picture of the 323 rear LCA and the same hole is just a smaller circle. so w/o having to spend another 140 bucks on the MX-3 sway bar, i wanted to see if i can just change over the LCAs which looks similar enough in photos to make me investigate.
same issue for the front, i have not yet bought a front sway bar, but i have bought the bushing kit for a 90-94 323/protege/escort/neon. same issue, the end flanges of the bar is vertical where the new upgrade endlinks require it to be horizontal, and in addition, there is no mounting point on the current MX-3 front LCAs. not to mention i haven't been able to find a MX-3 front sway bar upgrade, but there is a 323/protege one, so i'm wondering if the front LCAs can be swapped back over to the 323.
can anyone shed any light on this?
ps. i will post pics soon to show what i'm talking about if it seems confusing, but if u know the solution, im sure u know what im talking about.
