did the search to no avail... all it gives me is mostly coilovers. here goes.. what im looking for is the spring rates on the following cars . 323,egt,protege. what im doing is replacing 4 struts springs and so on . the stock 323 struts are way too soft for what i do with my 323. which is gravel roads and forestry roads. and i certainly cant afford the big buck coilovers for the off road stuff . any ideas???? what id like to accomplish is for the 323 not to hit bottom when i go off road. thanks in advance...
spring rates..
the only thing i can really suggest is to go with the mx3 V6 coil springs, they're a much heavier rate and will probably raise your car depending on the current condition of your springs...
for oem struts, the zx2 tokico s/rs would normally be ok...but they're shorter lol. So i'd recommend either KYB or Tokicos...
This setup obviously won't break the bank, and should do ok over your stock setup.
JACK.-Jack
yep the springs will swap right in-Jack
Originally posted by Mazda_Powered View Postthe only thing i can really suggest is to go with the mx3 V6 coil springs, they're a much heavier rate and will probably raise your car depending on the current condition of your springs...
JACK.
I've been looking for stiffer stock height sptings for a while too. I have zx/2 s/rs with some manner of lowering springs right now. The rear is just too low and weak. The front seems ok though.1990 Protege 4WD
1 3 5
2 4 R
the fronts are definitely a higher spring rate, double check mazdas part numbers to see if there's any different #s for the rear springs tho...i'd believe they would be heavier though.-Jack
Thanks.
Also wondered if Escort wagons might have stiffer rear springs. Maybe.........1990 Protege 4WD
1 3 5
2 4 R
true! i know escort gts have stiffer front and rear springs, they're the same as the "sport" protege LX springs you guys get in the US...might be the same as the mx-3 ones or the wagon...haha who knows!
we need someone with the proper equiptment to find out!-Jack
What equipment does it take to measure spring rates?1990 Protege 4WD
1 3 5
2 4 R
June '06 Moog Coil Spring catalog
Applications
Front CC882 91-96 Protege/Escort/Tracer 2/4/wgn (ex GT).
Rear CC853 91-96 Protege/Escort/Tracer 2/4dr (ex GT).
Rear CC855 91-96 Escort wagon
Front CC890 97-01 Escort/Tracer 2/4/wgn 2.0
Rear CC869 97-01 Escort 4dr 2.0
Rear CC867 97-99 Escort wgn 2.0
Rear CC871 98-01 Escort, (incl ZX2, ex ZX2 S/R) 2.0
Front
CC882 Load 466lbs Rate 162lbs/in Install height 9" Free height 11.88"
CC890 Load 690lbs Rate 156lbs/in Install height 7" Free height 11.25"
Rear
CC853 Load 274lbs Rate 113lbs/in Install height 11"
CC855 Load 324lbs Rate 113lbs/in Install height 11"
CC869 Load 394lbs Rate _85lbs/in Install height 10"
CC867 Load 426lbs Rate _85lbs/in Install height 10"
CC871 Load 342lbs Rate _90lbs/in Install height 10"
CC are Cargo Coils, which are a variable rate spring, the rates are averaged
Other applications of similiar size/type with greater load, spring rate.
7504 Front springs on '98-02 Chyrsler 300M, Concorde, LHS, Dodge Intrepid
7506 Front springs on '02 300M Special w/Sport Suspension.
7504 Load 1087lbs Rate 182lbs/in Install height 6.99" Free height 13"
7506 Load 1090lbs Rate 174lbs/in Install height 6.52" Free height 12.8"
There was only the above mentioned Protege listings. As far as Mazda listings there were only two cars listed, the other being '83-'87 626. And there wasnt a
Ask the parts store if they have paper coil spring catalogs and if so do they carry TRW, MOOG, Raybestos, Delco or Husky.
A newer MOOG catalog may just have the other models listed, although I doubt it if they didn't have them listed in '06 for a '90s car.
Replacement coils are not cheap either. CC882 coils list in the $70.00 US price range.-Michael
'90 Protege SE
Originally posted by charlesIt's probably to fix that ****ing automatic seatbelt
a set of AWD protege springs will definitely jack things up a bit
i had a set but they are sitting in a junkyard somewhere nowEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
