Alright so i've been messing around with my dad's 91 LX and it is driving me mad. Every time you get on or off the gas the car does a little wiggle in the front end. Also the front end will do a little wiggle when driving straight like when cruising and I go over a bump. So far I've gone over the front end and checked the tie rods, swaybar endlinks and the hub bearings. I also just replaced the front strut asemblies (strut, springs, top hat, etc...). I'm kinda at a loss right now and am kinda in a toss up between ball joints and motor mounts. Just wanted to see if you guys had any other ideas that I might be missing.
Front End Problems
Front End Problems
1991 Mazda 323 GTR Sedan
MODS:
GTR motor swap, F&R Familia strut bars, MX-3 Rear Lower strut tie bar, GTX front bumper, GTX grill, EDM headlights & corners, EDM 323 rear garnish, EDM spoiler, EGT sideskirts, MX-3 seats, GTX steering wheel, EGT glass sunroof, WRX hood scoop (functional!!), and other things that take too much space to list.....
TO DO LIST:
EDM/JDM rear bumper
EDM/JDM power folding mirrors
Repaint carTags: None
Sounds like tie rods. Did you check the inner tie rods? How'd you check the outer?1993 Protege LX-Midnight's shadow SOLD
Welcome back---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
welcome back indeed! whatever happened to that tarp-covered GTR motor?
check the LCA bushings. in my old escort they were worn and caused weird stuff like that.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
hey welcome back!!
i'd check bushing condition and make sure your steering rack bushings are not destroyed, you'll get a lot of play (feel like inner tie rod) if they are.
usually engine mounts will cause wheel spin and vibrations from what i've gathered.-Jack
Thanks for the warm welcome guys. Sadly the GTR is down for the winter with a blown trans, but the motor is fully operational again. But as far as this front end problem I know the swaybar bushings are shot and it's gonna need some new tires too cuz they have some unevn wear from the old struts I just replaced.1991 Mazda 323 GTR Sedan
MODS:
TO DO LIST:
EDM/JDM rear bumper
Repaint car
you should check out my toyota trans adapter plate group buy... perfect time to do it!Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Thereildeal: Yeah, I'll have to look into that trans adapter. How is the gearing for that Toyota trans?
Deathtrigger: Yup, I'm another boosted bp...There used to be more of us but many have been sold off and don't know where they are now.
Update on the car.....got some new Bridgestone RE960 pole postions, re-painted the wheels and installed new struts/springs all around with new ball joints in the front and a wheel alignment.....WHAT A DIFFERENCE IN THE RIDE. Now I just gotta stop being lazy and do my swaybar bushings....1991 Mazda 323 GTR Sedan
MODS:
TO DO LIST:
EDM/JDM rear bumper
Repaint car
Camry:
First Gear Ratio (:1) 3.23
Second Gear Ratio (:1) 1.91
Third Gear Ratio (:1) 1.26
Fourth Gear Rato (:1) 0.92
Fifth Gear Ratio (:1) 0.73
Final Drive Axle Ratio (:1) 3.93
Stock BG Protege:
First Gear Ratio (:1) 3.31
Second Gear Ratio (:1) 1.83
Third Gear Ratio (:1) 1.31
Fourth Gear Rato (:1) 1.03
Fifth Gear Ratio (:1) 0.795
Final Drive Axle Ratio (:1) 4.105
if you want to screw around with it you could run an MR2 final drive by either modifying the MR2 trans case or swapping the guts into a Camry trans. that final drive is like a 4.3xx, the rest of the gears are the same.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Deathtrigga: I'm in central NJ around Edison
Therieldeal: What about axle compatibility?1991 Mazda 323 GTR Sedan
MODS:
TO DO LIST:
EDM/JDM rear bumper
Repaint car
I figured the whole thing out, check out my build thread in BG Worklogs. The axles are hybrids, inner stubs from an MR2 turbo with CV axles from a celica alltrac. they fit the stock BG hubs.
I'm going to type up a full parts list and include it with the adapter plates.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
