Hi guys. I am having big issues bleeding my brake system on my 323 GTR jdm with ABS. As you guys know, the GTR master cylinder is electrical, not mechanical. During winter season I installed stainless steel lines and changed fluid for DOT4. I started the bleeding procedure as if it was a normal car, from back to front, with the ing. key on so that the actuator pump would pump the fluid thru the lines. After beeing sure there was no more bubble, I tought I was done. Still, pedal was going to the floor.
I got my hands on the right procedure found in the GTR shop manual (thanx to Robert Green) and realized that I need to start with front with the key off, then move to back with the key on, so that's what I did. Same results at the end, no pressure. Then I decided to change the master for a spare one. That's what I did, after I redid the exact same procedure called in the shop manual, with the exact same result. What are the odds that both masters are busted? I haven't found leaks in my system, we bled more than a liter of fluid to make sure they was no air anywhere.
Did I do something wrong? Someone here had to do so on his GTR and has a trick or knows something I dont? Some people tell me to use a vacuum system to bleed, other say not to cause it will bust the seals inside the master...
Please anyone help me with this, I a am discouraged... Thanx.
