As some of you may know, I installed an ST sway bar a few months ago. Since then, every time I make a turn or go over a bump stop the bar makes a popping sound. I've checked it numerous times and it seems to be installed perfectly fine. There is no movement anywhere. Could I have tightened the end links or frame mounts too much??? This has me worried because every time the frame of the car bends a little I hear that stupid noise...... Any suggestions will be greatly appreciated.
ST sway bar question.
'91 LX
'03 Mazdaspeed Protege #235
while you're out there, you might as well adjust your air/fuel ratio by smell... and your tire pressure by ride heightTags: None
Originally posted by cortez
Disconnect it from the endlinks and grab the end of the bar. Make sure that you can move (swivel) the end of the bar up and down. If you can't, then the frame mounts are too tight.
Check the endlinks for signs of them hitting anything or the bushing missing, etc.-------------------------
'91 LX
hummm i just installed these a few week ago myself.
i have to run to the store, I might as well check for that nose some times i hear a bit of a knock my self.Koroma
91 323BG-----------------------
Intax springs,PRM Air Intake
ST Swaybars, Front upperstrut bar, 15' Prime, Advanced Timing, 2.25 inch-Cat back, Flowmaster, Indiglo gauges, Custom Taillight config
Next Stage
J-SPEC GTX kit,Brembo Brake Kit
