Those part #s look familiar but I'd do a search to be sure. Darryl has posted them numerous times so you shouldn't have a problem finding them. Better yet, just ask for Theresa Valley when you call. She'll know exactly what you're looking for so you wouldn't have to worry about year/model/part #.
zx2 eibach springs
'91 LX
'03 Mazdaspeed Protege #235
aren't the tokiko zx2 struts lifetime warranty?1993 Protege LX-Midnight's shadow SOLD
Originally posted by turproaren't the tokiko zx2 struts lifetime warranty?-------------------------
'91 LX
Weapon-R and ZX2's
I'm running the Weapon-R Circuit Pro coil overs on my 90 protege. Is there any reason why the ZX2 struts would not work? Other than I have much more than a 1" drop front and rear. Right now i just have the stock replacement struts I got from napa years ago. If the zx2's are a shorter strut, then should I be able to get my car a little lower?
so let's see, i'll need:
- zx2 bumpstops (all 4)
- zx2(or generic, but the more exact the fit, the better) dust boots (all 4)
- zx2 front upper spring perches*
*i know i don't need them, but i would rather have the bearing and the perch match up than having to grind to match... me + grinder = bad
i'm going to call a local dealership on monday to at least price these things...
if it's out of my range, then i'm calling a j\y...
but that'd be a little difficult to dismantle all 4 strut assemblies on my lunch breakjustin
Protege - 1993 - White - LX - AT - 170k miles
installed--- Glass Sunroof, ZX2 S\R struts, Eibachs, custom intake, mp3 headunit, Enkei RS6 16" wheels
to install coilovers on the ZX2 struts, you need to trim down the little metal "hats" that go over the strut insert. I have ground-controls on some ZX2 struts on my MX-3, and the sleeves won't fit over these unless you shave them down some.
It isn't that big a deal, just takes a little time. You can pry them off also, but I didn't want the insert popping out all the time.93' Noble Green MX-ZE (sold )
