Just get a lot of heat guns, hahaha.
Kev's '98 Protege Thread
Some more progress has been completed. Projector is mounted and was temporarily put on the car to aim it. The shroud is trimmed, but still needs to be permanently fixed to the projector. Too much was cut off the top, but no one is going to see it with the hood down. You can still see some of the projector housing behind the shroud, but not really enough to notice if you just walk by and glance at the car. Well, on to the pics.....
Projector mounted, shroud set in, no lens.
The light isn't on, that's just the camera flash.
With the light on. Low beam, I believe.
Low beam from the driver's seat. Only about 3' from the garage door, I'll obviously take pics from farther away when it's done.
High beam. Again, very close to the door.
Still need to be done:
Tear apart passenger headlight
Mount passenger projector
Permanently mount shrouds
Wire up DRL's
Take lens off JDM headlights
Put JDM lenses on USDM housing
Clean up
Show off
thats some pretty slick ****!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Thanks man, here are some more pics....
Projectors in. My old 8000K HID kit is torn out, anyone want it?
And the finished piece....
I'll hopefully be able to take some night pics after work today. I just adjusted to headlights after taking those last three pics, so they should be as close to perfect as I can get right now.
those are really nice!!! mass produce them---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Night pics, enjoy. . . .
Low beams. The grass is higher than where the car is parked and they might be pointing down a bit.
High beams.
The driver's side is pointed way left, and I think the passenger's side might be also. I'll address that issue tomorrow night, too tired to care right now. As long as they're not pointing up into other drivers' faces, I'm fine with it.
still better lighting then before---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
