Hey Guys, i'm currently in the process of doing my BP swap. I came accross a few problems that may not be too severe and possible replacements.
First off, the clutch Pedal has no resistance at all and I can push it to the floor. It doesn't pop back up like normal clutch pedals so I am a bit confused. I have talked to a few people on their insights. My car used to grind gears badly anytime i put it in first gear, and it started in 2nd gear. So I bought another transmission incase it was the Synchos. But seeing as how the clutch pedal doesnt' want to act right, could it possibly be the clutch slave cylinder? I have been thinking that maybe the cause. I'm going to pick one up from Advance either way. Anyone have any other suggestions? We filled the brake resourvoir with full synthetic gear oil that was specified. My friend tried bleeding the clutch but everytime he did it, the clutch pedal got stiff and it was hard to push it in, then when I did, it seemed to go back to no resistance. I was told the possibility could be the clutch fork? Isn't it made out of steeL? When we put the transmission in, it looked like it was in good condition.
And 2nd of all, it seems like my motor isn't receiving the required fuel. When we put starter fluid in the intake manifold, the car started right up. So we know its a problem with fuel delivery. We pulled the feed lien to the fuel rail and very little fuel was coming out. It didn't have any pressure behind it. I was told to try and change the fuel filter which I'm going to try and do although the motor is in the car lol. Also, I was advised the fuel pump relay and the fuel pump itself. Any other suggestions that I might be able to look at in the morning?
Again, thank you all for those who helped me and for those willing to help.
BTW. Because the car started when putting the starter fluid in the intake and its turning over, it means the clutch is engaged. So I'm hoping I dont have any problems with the clutch kit because taking it back out would be hell.
