ahaahhahahahahahaaahahahahahaha . You got a ticket . Hey I've been trying to get in touch with JR and I just can't right now. I need to find a garage to finish the car.
Those are probably going to be to large. I tried putting in 280cc injectors and they flowed to much fuel. Even if you lower the fuel pressure to 32psi which is the minimum that can be run without problems with the spray pattern it will run rich enough to burn your throat. The stock injectors will handle up to 8psi and spray around 13lb's per hour. Your best bet are to get some18lb per hour injectors. The Nippon Denso Violet's out of a toyota 4age engine are the right size for the car and support 180hp.
I know it's spelled protege! I just can't change it. Deal with it!
