I've just installed a new clutch and engine in my 95 mx3. Everything went smooth as silk until I pushed my clutch in from the pedals and it would not return, or release. the slave cylinder works fine because it pushes the rod out from the cylinder which pushed the clutch fork forward, however.. me and a buddy have kind of concluded that either the clutch disk might be on the wrong way.. my clutch disk had 2 different sides.. one side was perfectly flat and the other had a center that pertruded off the disk.. we put the pertruding side facing the transmission, and the flat side on the flywheel.. and the throwout bearing was properly installed without a doubt.
does ANYONE have any idea what the problem could be? Could the problem be either the disk is on wrong, or something around the clutch fork? Any help or advice would be great!
Thanks!
Thanks!
