This is sort of the same as a 2.2 turbo, but in my opinion a much better swap. A 2.5 liter V6 out of a mx-6. I am going to attempt this swap in early spring and I wanted to know if anyone has any suggestions? I know I will have to do motor, ecu, tranny, and axles. Has anyone ever attempted this before? What am I getting myself into as far as wiring goes?????
Make sure you have a hacksaw ready, because I can tell you a BP just fits in the 2nd gen....
No way do I see a V6 going in there...
The flywheel should all second gen's. I seriously doubt it would have changed. Go to nopionline, I think they have the lowest prices for parts for our cars. They got one made by Clutch Masters and Unorthodox racing so check it out.
Answer to Flywheel ??????'s
95 1.8 uses the G tranny flywheel.
95-98 1.5 uses the F tranny flywheel
96-98 1.8 uses the F tranny flywheel
don't anyone ask again or you get flamed automatically .... lol hahaha j/k (not)
bruce,
i'm not too sure on this...but what if i just want to swap in the 1.8L engine into my 95 protege, keeping the 1.5L clutch, transmission. what axles would i need to use? going about the axles problem is my only dilemma. later on i'm going to add the 1.8L tranny, stronger clutch, and aluminum flywheel.
late
If you took out your engine and left your tranny, axles, clutch and flywheel ...
What axles would you use for the transmission that you are keeping?
ACTUALLY.... i think there's a possibility that the kl-ze might fit into a 2nd gen. call me crazy, but having closely looked at the bpt in the gtr, there seemed to have been less room in the gtr than there is now with the bpt in my 2nd gen! i have more clearance btwn the intake manifold and the firewall with the bpt than with my Z5-DE. the turbo fits about where the precat is on the 1.5L. what's throwing you off is the fact that the radiator sits BEHIND the front frame in the 1st gen and mx-3 whereas the radiator sits farther INFRONT of the frame in the 2nd gen. if people have been swapping the kl-ze into first gen's then i think it might work since there may be adequate space. just have a sledge hammer incase you have to make it fit.
but there's still a problem with the rear-mount dilemna...
HMMMM.
ahhhh, that's what i was hoping you would answer?lol so how'd you keep your 1.5L tranny in the car?
Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
I also have an mx-6 with a kf motor. Same size as the kl-ze just less hp. I still need to do some extra measuring, but I think it will fit. I was able to get a LS1 w/6 speed trans in my 97 m3, so I figure this should be a lot easier. I am worried about that darn power steering pump though.
Bruce the V6's size across is ledd than that of a BP. it is the firewall to radiator that uou have to worry about. and if memory serves me right the volume of the 2ond gen is very similiar to that of a first gen.
When you turn your car on... does it return the favor?
Originally posted by goldstar
Yes, still have it. It was my attempt to immortalize you in verse.
A Protege driver named Brock
So his engine he goosed
With much too much boost,
I just don't see a that motor fitting. I also don't think the engine bay of a 2nd gen is as big as my 323. Just by looking in the bay of my 323 I can see more room. But like with anything I could be wrong. I won't be the first to try it.. I rather the BP.
Bruce
Q - What do I have to do to the 1.5 engine wire harness to get it to work with the 1.8?
A - With the 1.5 wire harness you have to make some modifications to it inorder to get it to work. The modifications are not hard and more info and directions will be provided on my site in due time. You have to use a BP 1.8L MAF as it flows more air than the 1.5L maf. You will need the plug for the maf and will have to run two wires from the maf harness plug to the 1.5L wire harness and they connect to the front and rear oxygen sensor respectfully. Depending on if you are using the 1.5l distributor you can use the 1.5 harness plug. If you use the 1.8 distributor, then you will need the 1.8 harness disty plug. A seperate wire will also have to be run to the VICS.
Q- Do I need a partial 1.8L BP harness?
A - Yes you do need a partial BP wire harness it will save you a alot of heart ache. The reason you need it is because the BP and the Z5 use different plugs for the tps throttle body and water temp sensors. (also the MAF). You will need these to splice onto your 1.5L harness to make things work.
Q - Do I need to run a extra wire to the VICS solenoid?
A - Yes you do need to run an extra wire to the VICS solenoid. You will also need to add an extra add the pin to the plug on the actuall wire harness plug that connect to the ecu. You need the VICS as your car won't idle properly during cold start and you will get **** for gas mileage.
Q - Do I need a different down pipe ?
A - Yes you do need a different downpipe. The 1.5 downpipe is to short and low and won't fit to the BP engine. You can get one from a junkyard from any BP (1990-1994 lx protege).
Q - Will I get a check engine light?
A - Chances are yes you will. The reason is mainly due to the rear oxygen sensor. There are ways to bypass this. I may put up something that I am working on to try and bypass the rear o2 sensor, but that ramains to be seen.
