I have a '98 with auto trans. 180,600 mi. Water pump started leaking, so I had the timing belt and water pump replaced by my nephew. When I got it back it was acceleration was VERY slow, it was never a speed racer, but this was bad. I combed through the forums here and at Mazda3club.com and tried some ideas I found. I replaced the fuel filter, fuel pressure regulator and fuel rail. This improved the idle, it was very rough and almost stalled. Now it will start and idle fine and acceleration after about 8-10 mph (no tach) is better than it was. Starting out or pulling across a busy intersection is scary. It seems if slow even pressure on the gas pedal gives better, although slow acceleration.
Where do I go now? CEL has not come on, it was on before all of this work. Vacuum lines look OK, I don't know how to test them and I didn't see any cracks.
Please let mw know what you guys think.
Thanks,
Thanks,
